Greyed out components
garnesdata
Hi guys.
I'm trying to implement using # and * in a digits loop to confirm or go back. I just added menu to test this. When the input is # it writes the whole userinput (from the component c2) to this variable. I'm however not able to drag the c2 component to the the other option in the menu - it's greyed out. Is there a better way for me to go back one step? Screenshot 2022-08-18 at 12.44.24.png
Not sure what you're building but user components are usually only usable in the main flow. Not within other components.
Also, save.
I'm gathering different user inputs and playing the digits. Then saving into a csv.
Components are grayed out in order to avoid circular references. If you define the Component1, which is being used in Component2, which is being used in Component3, then you can't use Component1 inside Component3. Circular references are not allowed.
x1515
