Group Recordings
Alphabetic
3CX MVP
Is it possible to have users access group recordings but not see recordings of certain extensions?
Is this only acheivable using multiple groups?
thanks.
Yes. Once you give an extension access to Group Recordings, it is for the entire group. You cannot select which extensions of the Group will have their recordings visible. This is generally designed for Managers of a department.
bosdorf
