Group Rings One Extenstion only from a certain number
hornetsoft
We have a customer that has a group of 4 users 3 are yealink dect handsets and 1 algo speaker when a certain external number rings in only rings the algo speaker any other external number calling is fine
Just to remove some scenarios:
How is the group set up in 3CX (Ring Group, Call Queue, Paging, or something else)?
Is the Algo speaker configured as a paging/intercom device or as a standard extension?
The non-ringing extensions, do they have any exceptions configured in their Call Forwarding?
Ring Group with a Ring Strategy of Ring All
Algo Standard Extension
Exceptions are blank for all users under call forwarding
Just to be sure this only occurs when 1 certain external number calls
Any CID rules?
You may have to up your logging to verbose and check or run a wireshark.
if i change the group to prioritised and call from the specific number it flashes ext 100 101 102 very quickly then stays on 103 the algo as if some kind of forward
(Side question first, if the extensions 100 - 102 are logged in to the web client, do they ring there?)
If you log in to the dect base's own admin, can you check if it has it's own Block list?
If you are not sure how to do this, you can factory reset the DECT base and handsets, and re-provision, to bring them to a known clean state.
bunthoeun.may
