GRP2614 lost configuration on reboot
anog10
I have issue every time i restart the phone is reprovision and lost the configuration.
Like I mentioned in your other thread, you are able to do whatever you want but it makes it unsupported by 3CX.
2 choices in this case:
1. Remove phone from 3CX provisioning (remove the URL from the provision field)
2. Make a custom template with your changes and assign the phone to that template.
If you made custom changes that are normally provisioned by 3CX, then they will get overwritten every time the phone reprovisions itself.
SupportRock
