Solved GSC35xx - Phonebooks becomes bloated
Evolute IT
3CX MVP
Gold Partner
Just noticed that on my GSC that is used for pretty much testing only. The phonebook was around 1300 entries long. All duplicates.
It seems to be a simple misconfig in the template (see below). Can we get this fixed in the official template?
Code:
<!-- Clear The Old List/Clear Old History Mode. 0 - No, 1 - Clear all, 2 - Keep Local Contacts. Default value is 0 -->
<!-- Number: 0, 1, 2 -->
<P1435>0</P1435>
This should be set to 1 so that the GSC clears the contacts before downloading the new XML. Otherwise, it gets duplicates everywhere.
Hi Frederick,
Can you suggest a way to rapidly replicate this?
If you go to the Device UI > Calls > Contacts > More > Download Contacts, you can trigger it manually by clicking "Download". If "Clear The Old List" is unchecked, you'll see the duplicates appear.
When checked, the list will only update and not duplicate.
Thanks, we will take a look and get back to you
Hi Frederick
Thanks for reporting this. We released a template update that takes care of the contacts duplication problem.
Finatra.us
