Guest Wireless Network.
SonnyH
I have 3 networks setup: LAN (VLAN1), 3CX (VLAN2) and G-LAN (VLAN5).
and 2 wireless networks, AP1 (LAN) and other AP1-G (G-LAN).
The only difference between the three is the IP subnet range: LAN (192.168.1.0/24), 3CX (192.168.2.0/24) and G-LAN (AP1-G) is VLAN 5 (192.168.5.0/24).
AP1 works perfectly, AP1-G will not issue an IP address.
Also, if I switch AP1-G network setting to LAN or 3CX will get an IP in the respective IP range.
Any thoughts? What other info do you need.
  • Sad
Reactions: craigreilly
This sounds like a network thing that should be discussed with your IT guy or in an IT forum, not 3CX.
Reactions: ChrisC_3CX
OOps!, wrong forum.
Nari
