GXP1630 fw version not supported, no update
korazy
3CX Standard 16.0.6.655
13 x Grandstream GXP1630
In the Admin console, Phones, it shows all phones with the message Fw. Version Not Supported 1.0.4.132.
In Updates, there is no firmware update available.
Should I be updating the firmware on these phones? If so, to which version?
Thanks.
The PBX has already downloaded the firmware, and is showing you that phones are out of date compared to what is on the server.
Just go to the phones page. Select your out of date phones, and click "Firmware" in the menu at the top.
You will see the comparison of firmware. Select the phones you want to update and click OK.
Reactions: korazy
Thank you.
tohoken1
