gxv 3240 template
nasireth
New User
Can some please help with the gxv 3240 template for 3cx
I would strongly recommend changing the phone. A GXV3240 is old, EOL, slow and will not work great at all.
A T5x from Yealink would replace that easily.
A T5x from Yealink would replace that easily.i just wz
i just want it for testing purposes, i have alot of gxv3240 if you could help me with the template that would be great
you don't need a template for the GXV3240. Some templates from the net don't work right. Reset the phone to factory defaults, create a extension in 3CX without a template. add the extension creditals (telephone provisioning) manual to gxv3240.
For the first step, you dont't need to change any other settings in the phones web interface. it works without any issues for normal calls and video calls (check if the phone has the latest firmware installed)
You can tune the phone's codec settings for better audio quality, video calls, doorstations.... all works very well. If you have the BLF extension of the phone, you need to configure it manual in the web interface!
Finatra.us
