Ha 3CX
Felipe Medel
Platinum Partner
Good afternoon, dear colleagues. I have doubts when it comes to configuring the scripts for the HA's operation since I can't understand which scripts need to be loaded. According to the information provided by 3CX, there are several, but I don't understand if all of them need to be used or if you should select some. Similarly, do you need to configure anything in the scripts, or are they ready to work as is?
What are you trying to achieve? out the box the failover should be enough. the scripting is for any additional requirements you might have.
Reactions: N_G
Jake_Southern
