Unsupported Handle calls with non 3CX android app
steve.yon
Forum User
Hi there,
I would like to know if the 3CX android application implements the connection service as described in this doc (https://developer.android.com/reference/android/telecom/ConnectionService).
I am building my own dialer app to be able to filter wireless calls, automatically answer some calls and put it on speakerphone from a whitelist. It works very well for GSM calls but my main goal is to intercept 3cx calls.
In short, is there a way to not use the 3CX application, implement some things in my application and be able to receive VOIP calls with my own application? Or can I use the 3CX application with my own and intercept voip calls?
(I am only interested in receiving calls)
Best regards
Just use any SIP library but you will lose the Push ability.
And I don't believe you can intercept calls from another app beside GSM ones.
Thank you, i'm gonna have a look at it.
/dev/simon
