HELP!! Management Console keeps giving server error
Lugo Consulting
Hello all, as of yesterday morning, the management console is inaccessible. We are currently running on Debian and v16.0.3 3cx. All services are running, including the 3cxPhoneSystemMC01 service. I am able to reboot this service with no issues. I have also rebooted the server. The web client side is working perfectly. I have also patched the server completely to see if that would fix the issue, but no luck. Also, I have reviewed the management console log and no errors appear. Any other suggestions?
thats a new one... hmm....
Make any recent changes to SSL/TLS certs or settings, or do any updates just prior to this occurring?
database running?
BrenttG, The SSL certificate tried renewing starting on 1-25-2020 and expired yesterday 2-19-2020 at 5am. Unfortunately, it continues to fail with the following very non-descript error:
HTTPS Certificate renewal Failed - Error:
System.AggregateException: One or more errors occurred. (A task was canceled.) ---> System.Threading.Tasks.TaskCanceledException: A task was canceled.
--- End of inner exception stack trace ---
at System.Threading.Tasks.Task`1.GetResultCore(Boolean waitCompletionNotification)
at PostInstall.CertificateHelper.ProcessCertificatesDirectory(String directory, Boolean temporaryCertificateGenerated, Int32 regenerateNotSelfSignedCertificatesFrom, Int32 regenerateNotSelfSignedCertificatesTo, CloudServerStatus statuses, Int32 regenerateCertificateExiredInDays, String appBin, UInt16 sipPort, UInt16 tunnelPort, Boolean isPassiveFailoverMode)
at PostInstall.CertificateHelper.RenewCertificates(String appBin, String nginxConfigFolder, String configurationPath)
---> (Inner Exception #0) System.Threading.Tasks.TaskCanceledException: A task was canceled.<---
CraigReilly, not sure which service is the database service, however, all services are running.
