Help using GOIP as a gateway in 3CX
FlyingVOIP
I'm trying to move from Elastix v4 to 3CX and using my current GOIP4 as a gsm gateway in 3CX for both inbound and outbound calling. I've done many searches here in the forums and in google too without luck, unfortunately, VOIP status is still down, cannot register as showing in GOIP status page and in SIP trunks page in 3CX as well.
My setup is:
1. 3CX version 15.5 (Tested locally in the same network and on the Cloud)
2. GoIP4
Firmware Version: GST1610-1.01-64
Module Version: M35FAR02A01_RSIM
- Facts:
1. GoIP4 can ping 3CX in both directions
2. GoIPv4 works like a charm with Elastix
3. I can properly use 3CX to register extensions and calling internal extensions such voicemail
- 3CX Config
https://ibb.co/bsRjOz
https://ibb.co/dJB7bK
- GoIP Config
https://ibb.co/n4o9qe ( Tested in both Config by Line and Single Server Mode )
https://ibb.co/fyoyiz
https://ibb.co/isBvVe
https://ibb.co/cia0wK
https://ibb.co/mzvdiz
- My current working Elastix config
https://ibb.co/c2NYiz
https://ibb.co/iy58GK
I'm also seeing success attempts to use GoIP with 3CX but most of them are since a couple of years ago. Is it possible that the new versions do not support this gw integration as a generic device anymore? and can you please advise on how to properly configure this?
Thanks in advance!
cur_cb
