Hide unregistered extensions, system wide
Mike_S
Platinum Partner
I've Googled and can't find my answer. If it's not possible, maybe add this to the "suggested features list"
In 3CX V20, you can log in as a User and go Settings -> View -> Hide Unregistered Extensions. As an administrator, is there a way for me to do this on a users behalf (either as an option across the system, or from Admin -> Users -> Options or something)?
Alternatively, I'd suggest having Hide Unregistered Users as a default, and the users can go Settings -> View -> Show Unregistered Extensions if they want. It makes WAY more sense to have the system be tidy and not showing band-aid extensions used for mobile forwarding, call flow rules etc etc
Reactions: aspectian
This is only an option per user and cannot be applied globally to the PBX.
Is there a way to add this to suggested features?
  • System wide toggle
  • Ability to edit users from admin portal
  • Ability to bulk edit users
  • Suggestion to have it off by default
Reactions: EmmettsIT
DejanMDS
