- Joined
- Jan 10, 2024
- Messages
- 1
- Reaction score
- 0
3cx version: 18.0 update 8 (build 939)
How I set up holiday voice message:
Go to settings > Lanugage & Office Hours > Configure Holidays > +add the holiday and add the .wav file as prompt
This is our inbound rule:
When I set up a holiday in "configure holidays", instead of playing my customized holiday prompt, the system will route the caller to IVR 802 (Outside Office Hours IVR).
I have a few questions:
1. to make it work as expected (play the customized Easter prompt during Easter), should I tick the "Play holiday prompt when it is a global holiday"?
2. I'm a bit confused about: "Play holiday prompt when it is a global holiday"
does the global holiday mean the holidays I added in "Configure Holidays" or some default global holidays in 3cx system?
If I tick this option, will it use the holiday prompt I uploaded in "Configure Holidays" or will it use the Ext. HOL IVR?
Thank you.
Thank you.
