Holiday Prompts V18 Update 5 Beta
torresfrank1
Trainee Partner
Hi there, I just noticed that when there is a holiday set in this beta of 18.5, there is no holiday prompts. Instead, there is dead silence. I also noticed the issue with a call flow in place. If I remove the holiday from the settings, everything works as expected. I can figure it out using Rest API for a workaround, but there is something off with the holidays in this version.
Hi torresfrank1
We checked this and the holiday prompt works as expected.
Is it possible that the audio file that was used as a Holiday Prompt was deleted from the system?
To check it, please navigate to Settings->Language & Office Hours->Configure Holidays. Edit the configured Holiday and check if there you can see the prompt and select it from the dropdown.
I tested afterward, and it worked. I am not sure what happened there. I'll keep an eye on it.
georgi
