Hosted 3cx in azure, teams integrations and new azure communications services
Martijn Frerejean
Trainee Partner
Since there are ssl requirements to setup the teams integrations it doesn't seems possible with the 3cx domains? am i correct or missing something?
I think i need a personal ssl or custom domain installation.
Did anyone try to make 3cx connect to the new azure communication services direct route?
Reactions: Martijn Frerejean
After posting i found the instructions thx for the link.
So anyone on the second part of the question?
What do you mean? The set up with use Direct Route to link Azure with your 3CX.
Anything other than 3CXs set up is unsupported so I wouldnt even bother.
gmacinit
