HotDesking Compatibility Phone List
thetissot
As above,
You can also get the list if you config a hot desk extension - Advanced - HotDesking - Click on Add, and you will see the supported phones in the drop down list
You select T46 as the phone type - this applies to most of the Yealink TxxG range, you remove the G.
[email protected].
