Oh right, I forgot about the CFD. Little over the top for basic set of office hours, but why not.. thanks!There's several work arounds depending on what you are trying to use the hours for.
- You can set your hours from 00:00 - 23:59 and then use break times to block out 02:01-10:59.
- You can use office hours in conjunction with dummy extensions to handle routing
- You could handle call routing in a CFD
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
