How can I create loops by moving between the various components?
_aMiCiCi_
Hello, as you can see from the attached screenshot, I have created various components within the main menu (second screenshot).
How can I create loops from inside the component to the main menu?
Practical example:
From the "modify_delete" component I have to be able to go back to the main menu by pressing button 3.
devo.it
