How can I modify the SMS output for a generic SIP trunk?
greychain
Gold Partner
3CX does a simple SMS post using the first format listed below but I need it it the second format. Can I achieve this within 3CX or will I need to write and host an app to do this?
curl -X POST
--header "Content-Type: application/json" \
--header "Authorization: Bearer YOUR_API_KEY" \
--data '{
"from": "+10987654321",
"to": "+11234567890",
"text": "Hello John, how are you?",
curl --location --request POST 'https://smsprovider/rest/send?private_key=Private Key' --header 'X-Secret: Secret' --header 'Content-Type: application/json' --data-raw '{ "sender": "SMS Info", "to": "855123456789", "content": "Hello from rest API"}'
curl -X POST
--data '{
You'll need something to convert the request data. Check out AWS Lambda for this, it's free for 1M executions per month. Have AI build a small proxy to translate the requests. You'll need to make sure to return the expected data for 3CX too (message status, ID, etc.)
The docs here can help: https://www.3cx.com/docs/supported-sip-trunk-requirements/#h.z7xet9uflkmo
Thanks, I'm a bit lazy so just did it in php. Was hoping there might be a way to modify the 3CX template.
Unfortunately no, the format is hardcoded.
Jake_Southern
