How do I convert a Postman body statement into a 3cx CRM template
greychain
Gold Partner
I am using Postman to test the SuiteCRM V8 API. For lead creation it produces the following request:
Post {{suitecrm.url}}/V8/module
with the body details
"data": {
"type": "Leads",
"attributes": {
"phone_work": "0123456"
How do I encode this into the Template generator format?
In the XML template you can use the following request:
XML:
<Request Url="{{suitecrm.url}}/V8/module" RequestType="Post" RequestEncoding="Json" ResponseType="Json">
  <PostValues>
    <Object Key="data">
      <Value Key="type" Type="String">Leads</Value>
        <Object Key="attributes">
          <Value Key="phone_work" Type="String">0123456</Value>
        </Object>
    </Object>
  </PostValues>
</Request>
Thanks for that it seems to be working now. Plus I now know how to format post to xml
Mueller
