How do I Creat a Tranf to VM Box AP
Gerry G
How do I Creat a VM Auto AttN that sends call to vm box not the phone?
Gerry
Within a Digital Receptionist?
Just make it a menu option.
Hello @Gerry G
You can either add an option the caller can select or you can forward all calls to a specific voice mail box as suggested by @craigreilly or forward all calls of that Digital receptionist to a voicemail box.
You can do so by configuring the "If no input within seconds:" option to 1 second. So once the prompt stops playing the call will be forwarded to the assigned voicemail box.
