How do i find my talk link to put on my email signature?!
nandaphysio
I am referring to
'3CX Talk links which enable anyone to call you for free using their browser. You can place your talk or meet link anywhere from your website to your email signature.'
This is what the guide says but i think this is for startUP, my system is self hosted and i use a mac so i can't install the desktop application.
  1. Open the 3CX Desktop Application.
  2. Click “More”
    Ntg93L5k0PXeSIQM1knhornnf4_wJJpNoVyGi3nYk4bHb9o5lxqNtIngBsFfFNohjlkgil5aVLikfxnpAcFDAn-W-1-vWhEy7-1uhNiJEpkPGHfXrri9-H5DiYswu5gagy9Q_ikFV2EP0aE
    on the left side navigation panel and select “Settings”.
  3. Under the “General” section, see the “3CX Talk” settings
  4. Enter a friendly name into the field. The “Talk” and “Meet” links are automatically updated.
  5. Use the checkbox to choose if you want to approve participants before they join a meeting.
Thank you!
You can try locating the 3CX Talk in the Web client.
  1. Locate the welcome email (the “Your User Account on your New 3CX System” email).
  2. Log in to the 3CX Web client using the extension number and password you can find in the welcome email.
  3. Click “More” on the left side navigation panel and select “Settings”.
  4. Under the “General” section, you can find the “3CX Talk” settings.
  5. Enter a friendly name into the field. The “Talk” and “Meet” links are automatically updated.
  6. Use the checkbox to choose if you want to approve participants before they join a meeting.
In regards to the desktop application, you can install it also via the web client. You should see Apps on the left-hand side bottom page or simply click on the macOS icon at the top of the side menu, then follow the steps to install and provision the app.
I hope that the above helps.
Hi, Unfortunately my webclient doesn't have those options, please see the picture attached. I do have a general tab under settings but it does not have 3cx talk settings.
I cannot see any picture attached to your last reply and would recommend you to email details to [email protected], so we can check it for you.
Here is the picture, sorry for some reason my picture was removed on the earlier post. And yes i am on update 4 (version 18)
This is the admin portal wich you are showing , they mean the actual 3cx client as in the softphone
Reactions: IrinaP_3CX
hi, yes i have solved it! silly me i was looking at the management portal this whole time! i had to be logged into the webclient! thank you everyone for your help!
