How do I make it show me offline in 3CX?
checkinyyz
I do not have it set to ring calls to my mobile simultaneously, and my laptop is shut down which has the 3CX phone. I only have it on my cell phone, but I went to "Exit - Ignores PUSH" but calls still ring on my 3CX softphone on my cell and it still shows "Green - Available" to all other users on 3CX including the admin console. When my other users have their laptop turned off (that do not have it on their cell phone as well) it actually shows them offline. Other than deleting it from my cell every time I want to appear offline, is there something else I'm supposed to do?
Hello @checkinyyz
Please note that having Push enabled on your extension will keep your extension Registered in the management console. Even if you Exit-Ignore Push, that applies for the client and the PBX will still send Push to the extension. This is happening as the PBX and client do not have constant communication once you close the client and they rely on Push to be able to receive calls. I would recommend using the status of the extension and switching to DND when you want to go offline.
WagnerFT
