Solved How do I reboot 3CX linux server?
William Hall
I can't see anything on the GUI and if I login via SSH the commands "reboot" and "shutdown" are not recognised.
Hello @William Hall
Please note that you can only restart the PBX services from the management console not the entire operating system. You will need SSH access to the machine the PBX is installed on to be able to reboot it.
As I said I have ssh access. If I say "shutdown -r now" I get "-bash: shutdown: command not found"
I login as "admin"
log in as root, then just issue the command
Code:
reboot
"Admin" is not the same as "root". It is not recommended to login as root. Ever. Always use sudo to run commands with elevated privileges.
If you have ssh access, the do the following:
Code:
sudo reboot
or
Code:
sudo shutdown -r now
The first is a more modern way to do it. The second is a more granular, older way to do it.
Both accomplish the same thing.
Reactions: Shadragon
Thanks. "sudo reboot" works
Marari is correct. Always use sudo to elevate admin (or whatever Linux account you need.)
Reactions: Marari
Bluebox Global
