How do I route my call into the 3CX PBX?
Clayton Cleve
I am super new to setting this up and thank goodness that there was a express set in the cloud. I'm not a techy person but have used grasshopper, freshcaller, Phone.com etc. There you would buy a number and it would be available to call in to and then I could set the queue, dial an extension etc.
I'm struggling to find how I setup the call in phone number for example, 800.xxx.xxxx or a local number. Can anyone help me with a guide on how to use a phone number with this system? I have setup several extensions in the system but not sure how to route a call into this system after someone calls a number.
Update: I believe that we need to get a direct dial number. Is there any recommended direct dial providers that will integrate with the 3CX pbx?
You must first subscribe to a VoIP service provider. You don't have to have a Direct Dial Number (DID) unless you are planning on having several incoming numbers, with each routed to certain extensions. 3CX has a list of recommended providers https://www.3cx.com/partners/voip-providers/ and using one of those would make for the easiest set-up. There are some free services that will route toll free numbers for you. http://www.sipbroker.com
Once you have provisioned an outgoing trunk to the provider, you must create outbound rules to route call over the trunk. https://www.3cx.com/blog/voip-howto/outbound-rules-a-complete-example/ You must also decide where you want incoming calls to go. https://www.3cx.com/docs/manual/inbound-did-call-routing/ That could be a ring group, a single extension, or a digital receptionist. It all depends what you want the PBX to do for you.
If it is a simple home installation, you might want to put all extensions into one ring group so that anyone can answer an incoming call.
Every installation is going to be different.
If you search through the 3CX site, there is a lot of information on first time set-ups.
https://www.3cx.com/3cxacademy/videos/basic/installing/
GemmaC
