How do I update to v16?
craigreilly
v16 Release is not showing up under my updates.
Does this mean Auto Update is not available from v 15.5 ?
9978
If 3CX is running on a Windows machine, then you have to reinstall 3CX.
I read that was only if you installed Alpha or Beta on the Windows machine.
With windows , with major updates you have to backup, uninstall and reinstall.
Just make sure the backup file is save to another location than the default 3cx folders.
Reactions: Nick W
You need to perform a re-install as V16 has a new service and a re-install is needed for the service to be added. This is not the case with Linux however where the service can be added with an update.
copy. thank you. didn't remember this from the last major updates.
kevlaboom
