How does 3CX determine to use internal RTP ports or external RTP ?
greychain
Gold Partner
I have a customer that is using a VPN to connect to the SIP provider and I noticed it is using the port range 7000- not the expected 9000-
Its the expected and correct behaviour. As its a VPN its considered a local connection so it will use normal LAN ports.
Thanks,
mazet
