How i can get EXT digit after answer call ?
Mekaeil Andisheh
Hi @edossantos
we want to get the Extension digit from our website and know which one Ext answered the call ?
can you help us
thank you so much
Is this during the call, or after the call. If after the call, you can use the CDR files to determine who answered the call. If during the call, you can use the Call Control API to monitor "connected" events.
Reactions: Mekaeil Andisheh
Thank you so much @voiptoys
we want the data during the call , can you tell me how i can use Call Control API ?
please give and example or if you have docs link, give me the documentation link.
Thank you so much
The Call Control API documentation can be found here: https://www.3cx.com/docs/call-control-api/
You will need to subscribe to the events, evaluate whether the event applies, then take the necessary action. This will need to be a .net C# application running as a service (either a Windows service or a Linux daemon depending on your platform).
NathanMitchell
