How to add multiple external numbers - Forwarding rules
nkaud
Intermediate Cert.
How can we add multiple external numbers under forwarding rules---> forward to external numbers.
Thanks to helps.
Reactions: Shaqib Lallmamode
Do you mean calls from x go to external1 then try external2 like a ring group?
I imagine you would have to create a dummy extension with the forwarding rules set to your ext number (per external) then stick them in a ring group (round robin) and set up your forwarding to the RG.
Theoretically it makes sense but i'm not sure if it works as i've never tried it.
Reactions: nkaud
For what you want to do, create "dummy" 1 extension for each External Number, and in the Forwarding Rules of the Extension, se the "if not registered" rule to send calls to the External Number.
Once you have all these "dummy" extensions, put them all in a Ring Group. Now in the Extension that you initially wanted to forward to all the External Numbers, just point it to the Ring Group you created.
Be aware of your Sim Calls though, each call initiated to an External Number will count on your Sim Calls while they are all ringing.
Reactions: nkaud
2B_JPS
