How to change Daylight Savings Date
it26
The old date for Los Angeles was March 12. THe new date is March 8. How can I change the date for all my phones? Other phone systems have a global date setting, but 3CX does not appear to have that in version 15.5. Thanks.
What phones are you using?
Do the phones themselves have a setting? Many devices have an NTP setting and set time independent of the PBX. Any daylight setting that uses a specific date, for the change over, is not going to be correct the next year as the date will probably be different.
They do, but that would be a nightmare to have to change on each phone. I would think there was a global setting for this, or maybe I have to do it via a custom template?
Hello @it26
Which PBX version are you running and what phones are you using? Are your phones provisioned using the default template?
Xeniosg
