How to change from My SSL cert to 3CS SSL certificate
it26
I currently have a GoDaddy cert that I use on my 3CX server but its become a pain to renew every year and I would like to switch my config to use the 3CX SSL cert. Can anyone provide any instructions?
For that you need to use a 3CX FQDN. You cannot use your own FQDN with the 3CX Let's Encrypt integration.
You'll have to backup without license key, uninstall 3CX, release your FQDN in the Customer Portal and then reinstall using the same license. It will ask to choose a FQDN and just choose a 3CX one.
You will have to reprovision and reconfigure apps, deskphones and SBCs for them to use the new FQDN. In the meantime, what we like to do is a forward from the old one to the new one.
Reactions: KBRV and ChrisC_3CX
WagnerFT
