mikeodo Titanium Partner Advanced Certified Joined Mar 14, 2019 Messages 231 Reaction score 35 Aug 31, 2019 #1 Hello! How i cang change (V16.2) the 77/777 from the PIN Protect IVR?
leejor Customer Joined Jan 22, 2008 Messages 16,670 Reaction score 1,658 Aug 31, 2019 #2 Can you provide a bit more information. 777 is the echo test. Are you concerned that people calling into an IVR are going to dial that in error, or deliberately? Are you asking if the echo test number can be changed? Last edited: Sep 1, 2019
AWS2P Silver Partner Advanced Certified Joined Jan 9, 2014 Messages 5,077 Reaction score 1,096 Aug 31, 2019 #3 if this is probably hard coded in 3CX system extension number , so no chance at all you can switch to something else. Last edited: Aug 31, 2019
mikeodo Titanium Partner Advanced Certified Joined Mar 14, 2019 Messages 231 Reaction score 35 Aug 31, 2019 #4 I mean not the Echo Test. Echo test is *777. I mean ->
AWS2P Silver Partner Advanced Certified Joined Jan 9, 2014 Messages 5,077 Reaction score 1,096 Aug 31, 2019 #5 Default PIN protect IVR is 777 and you want to replace as 77 ? that's it?
leejor Customer Joined Jan 22, 2008 Messages 16,670 Reaction score 1,658 Sep 1, 2019 #6 Changing this parameter, was removed in Version 14, as I recall. https://www.3cx.com/community/threads/change-system-numbers.50817/
