How to check the echo problem?
Grace Liu
Platinum Distributor
Does anybody meet with the problem like this?
We made the bridge settings between two 3CX servers through VPN, when the extension of server A was in one call with the other extension of server B, the extension of server A heard the echo, and the other extension of server B didnot hear the echo.
1. the extension of server A can be yealink T42S and windows desktop app;
2. when we check the recording file in server A, we can hear the echo too.
Do you have any suggestion to check the problem?
I would set up the Bridge through port 5090 - then you remove the VPN overhead and herby - possibly - also the echo.
Run a wireshark and see what audio is being sent.
Jake_Southern
