How to create an outbound rule for extensions in it to be able to call only specific number
vincent Kavila
I have an outbound rule for some technical guys, I wanted to create an outbound rule that allows them to call only one number.
Is that possible?
Create yourself an extension group with your technical guys in.
Make an outbound rule that specifies calls from this group > ROUTE 1 > BLOCK
Move this to the very top of the list
next group:
Specify technical group > calls to <specific number> > ROUTE 1 > <SIP Trunk>
Move this to the very top of the list (Higher than the block rule)
hughesdouglas
