How to get a OAuth2 Token
Jijo_Raj
Forum User
Hi ,
I tested the contact lookup query in 3cx intergration portal and it worked. Now i want to build a custom CRM in which im going to integrate 3cx.
Now can you please tell me how to get the OAuth2 authentication
What do you need exactly? Instructions on how to build a server that provides OAuth2 authentication? Or you want to create a CRM template that uses OAuth2 authentication?
postmaster@studiolegaleda
