How to get detailed duration info of calls?
furkankzn
Forum User
durationtime-starttime-answeredtime-end
00:03:372020-10-05 07:44:472020/10/05 07:44:472020-10-05 07:48:25
Data from CDR
Data from 3CX Management Console, Call Log page
CDR data doesn’t give detailed information like one at the management console. I need the detailed duration information in a call. Filter in 'call log page' calls endpoint below:
https://pbx.mykredit.com:5001/api/CallLog
This endpoint gives the data that I need but it’s filtered by only one phone number at a time. I wonder is it possible to filter by multiple phone number or is there a documentation for API. Also, I tried basic authentication, but it didn’t work.
https://pbx.mykredit.com:5001/api/login
I use this endpoint to get the necessary cookie to make request.
If it is possible to fetch data from a source like CDR where is it but if I should use API how to filter data by multiple phone numbers and how to authenticate to API?
intoxtech
