How to get information from the SIP header
uniscanadmin
Integrations - Call Scripts: Is it possible to obtain SIP protocol values using a script? What fields can be obtained?
I'm also interested in understanding how a script works and at what stage it operates.
No you cannot access SIP data from call scripts.
And scripts can run two ways: when dialed, or whenever a call enters a trunk, in which case the script is called during routing prior to deciding a route, allowing you to override. Check how the holiday script works for a better understanding.
The only way to get SIP headers is building your own SIP client....
x1515
