Thanks a lot, I will check on this since they create a custom field on their end, i will try to figure out which data name it returns.The integration will return the following numbers if set:
<Variable Name="Phone">data.Phone</Variable>
<Variable Name="HomePhone">data.Home_Phone</Variable>
<Variable Name="OtherPhone">data.Other_Phone</Variable>
<Variable Name="MobilePhone">data.Mobile</Variable>
<Variable Name="Fax">data.Fax</Variable>
<Variable Name="AssistantPhone">data.Asst_Phone</Variable>
So you could have multiple numbers, and all of them will be returned.
Zoho are usually easy to guess "My Phone Field" will be "data.My_Phone_Field". Just need to copy the Zoho template, rename it and make your custom version of it to map different fields.Thanks a lot, I will check on this since they create a custom field on their end, i will try to figure out which data name it returns.
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
