How to make calls without prefix when more SIP trunks are configured
apitsos
SOHO User
Hi there,
I have a complex issue to solve. On a 3CX PBX V18 I have several SIP Trunks and I use prefixes in order to select a specific line to make a call from an extension. This becomes a big problem because the phone numbers (e.g. SIP Trunks) are becoming more and more and we are very close to 10.
  1. Firstly, I don't want to have two-digit prefix in order to solve the problem when the lines are more than 10.
  2. Secondly, I would like specific extensions to be able to make calls from a specific line, without using a prefix.
  3. Then I would like to block some extensions to use other lines with a prefix.
Is that possible? If yes, how could I configure it?
Thanks a lot in advance for all your help!
With kind regards,
Angelos Pitsos
Please note that in this case, you may separate extensions and add them to Groups. For example extensions 100-199 to Group1, extension 200-299 to Group2 and so on.
Then in the outbound rules for a specific sip trunk create an outbound rule only for this group of extensions.
Reactions: apitsos
Hi @TheodorosG_3CX,
Could you please let me know if such a configuration would be good?
With kind regards,
Angelos Pitsos
Hi @TheodorosG_3CX,
I'll check them. Thanks a lot!
With kind regards,
Angelos Pitsos
Reactions: TheodorosG_3CX
mazet
