How to provisioning Alcatel Phones 8001 IP Phones with 3CX
falkkes4
Hello all,
How i can provisioning Alcatel Lucent Phones 8001 IP Phones with 3CX?
thanks
As it's an unsupported phone model and brand, then only solution is to set it manually from phone GUI
thank you for your reply , but what configure should i do ?
factory reset phone if it has been previously used, then go in 3CX console settings in one extension
in same time connect manually from a browser on phone GUI, once connected search for SIP accounts and then set what you need coming from 3cx extension.
Unregister .
what should i choose in Phone Provisioning on 3cx console settings ?
i have fill the Extension ID, password and SIP server on phone GUI. but unregister.
your Adv
thanks
paste a screen copy of phones settings you've tried
I have solved the problem. it was the network connection it was a different range.
thanks
Reactions: AWS2P
hughesdouglas
