Solved how to see ACTIVE CALLS
BABALUCHA
Hello Everyone
Qucik question , how do i see active calls on the hosted Pro pbx .Thanks a lot in advance :)
In the webclient, you can use the panel to see active calls.
Reactions: BABALUCHA
Note also that the user must be part of all the departments in case you are using multiple.
Glad to hear that you have found your solution.
Have a great day!
DrunkeMeister
