how to set the maximum call duration in 3cx v20
Shaki007
how to set the maximum call duration in 3cx v20. i want to limit outbound call duration maximum 2 min, after 2 min call have to disconnect automatically.
Hi, did you search forum / google for this ? I ask simply because - already with a quick look I can find some discussion, as per
https://www.google.com/search?q=3cx...gzODc4ajBqMagCALACAA&sourceid=chrome&ie=UTF-8
which leads me to
which suggests built-in to 3cx is a 3hour per-call max limit, but this is not intended to be changed. But maybe if you wish you can blackbox-hack to make a change. (ie, not easy , not intentionally an option to change in 3cx, not a feature that is supported really).
other scenarios discussed include looking to your SIP DID Voip carrier config and see if there is a way to implement hard call duration limits on that side. ie, if 3cx won't easily let you force drop calls after 2minutes then possibly your SipTrunkCarrier can do so, and 3cx will just end up having lots of callDrops (by design) (?)
Tim
LeeonLau
