How to setup 3cx with Audio code mediant 1000 Gateway
enakeh
Hi all,
I need help setting up a 3cx gateway trunk with an audio code mediant 1000 gateway.
Both systems are not authenticating
04/30/2020 9:49:57 PM - [CM102001]: Authentication failed for AuthFail Recv Req INVITE from 10.11.56.253:5060 tid=ac1959674603 [email protected]: INVITE sip:[email protected];user=phone SIP/2.0 Via: SIP/2.0/UDP 10.11.56.253:5060;branch=z9hG4bKac1959674603 Max-Forwards: 70 Contact: <sip:[email protected]:5060> To: <sip:[email protected];user=phone> From: <sip:[email protected]>;tag=1c1914495532 Call-ID: [email protected] CSeq: 2 INVITE Allow: REGISTER, OPTIONS, INVITE, ACK, CANCEL, BYE, NOTIFY, PRACK, REFER, INFO, SUBSCRIBE, UPDATE Content-Type: application/sdp Proxy-Authorization: Digest username="sip",realm="3CXPhoneSystem",nonce="414d53595eab39f584:d6c4163a8defd7dd866f7760421377c3",uri="sip:[email protected]",algorithm=MD5,response="f9ee5d25674279512312a50fd073fbc0" Supported: em, 100rel, timer, replaces, path, resource-priority, sdp-anat User-Agent: Mediant 1000/v.6.80A.231.002 Content-Length: 283.
The trunking on 3cx is IP base and should not need authenticating.
help needed urgently
Bluebox Global
