How to show caller number when using ring also on mobile
Frank Yu
How we show the caller number when using this option? Currently it displays user's DID number, not caller number in her mobile.
Hi Frank, the voip provider should support Clip No Screening (CNS) in this way originator caller id will be sent.
what is your voip provider?
Could we see this option in 3cx Console, our provider is china telecom
Hi Frank, if you mean China Mobile then they do not support clip no screening and also these trunks can only be used with dedicated servers only.
Have a great weekend!
Reactions: N_G and Evolute IT
Hi Alejandro, It's China telecom, There are 3 big vendors in china, China Mobile,China Telecom,China Unicom
Ok Frank, but sorry China Telecom is not listed as supported VoIP Provider and using the Free or SMB you have to use a supported SIP Trunk
Reactions: Alejandro_3CX
You are welcome!
robroye
