How to show more granular recordings details?
davide.bonavita
Hello fellow colleagues,
I was wondering if there's a way, inside the web client and the management console, to show some other details regarding the recordings, like the length, the file size, etc.
On the same note, in the management console I can see in the "To" column the called number and the ID of the used trunk (e.g. 10008) but there's no way in the Trunk section to find out which trunk has that ID assigned
this trunk ID is no more displayed, it was available in old 3CX release , do you have lots of trunk on your PBX ?
"only" 5 trunks :) I mean, if I scroll the logs I can see the association between the ID and the trunk name, so I could note it on a post-it, but it's not the best solution
bosdorf
