How to uninstall the 3cx DesktopApp?
rscott101
Been trying to remove this from all our machines (so we can force people over to the PWA), but when running uninstall from add/remove programs, it fails with an error "This action is only valid for products that are currently installed." ?
Has anyone else encountered this error and have suggestions for fixing this?
Sounds like your AV already removed it.
Nope. Crowdstrike is just blocking access to the executables. The app still shows under add/remove programs and the files are still present.
Could you perhaps try using an old MSI if you have one (obviously don't use one of the versions impacted here) and calling
Code:
msiexec /x 3cx.msi
? Just a thought.
Hmm - thanks. Tried that, but didn't work. I'll try installing that version then see if it'll let me uninstall.
Stop-Process -name 3CX* -Force
$application = Get-WmiObject -Class Win32_Product -Filter "Name = '3CX Desktop APP'"
$application.Uninstall()
Remove-Item C:\Users\*\AppData\Roaming\3CXDesktopApp -Recurse
Remove-Item C:\Users\*\AppData\Local\Programs\3CXDesktopApp -Recurse
Remove-Item "C:\Users\*\Desktop\3CX Desktop App.lnk" -Recurse
Jeremy Hofex
