How we assign group manager in 3cx Console
Frank Yu
I create a group in 3CX, but we can's see the option how we set a role as manager.
You have to edit the user(s) to change their roles, in the Rights tab of the user settings.
yes, thanks ,permisssion issue ,it's grey before, now my manager assign this to me.
how we see the recordings ,which interface.
You should be able to see the recordings in your Webclient. Ensure that the option "Show call recordings" is checked in the Phone Provisioning tab of your extension settings.
how check group extension recording as group manager?
Is the right "Can see group recordings and reports" enabled in your extension?
Reactions: Frank Yu
Make sure the group you are a manager of has the last checkbox turned on for your role, like so:
AshleyStokes
