I can't call.
atlantisegidek
Forum User
My English is weak, sorry about that.
3CX Web Client or 3CXPhoneforWindows apps the call is coming. But I can't call someone else.
I write the number, click on "call", it does not react.
Thank you.
do you have set almost one outbound rule ?
Reactions: atlantisegidek
Hi @atlantisegidek
You cannot make any outgoing calls without outbound rules.
I would suggest to make use of our academy which will teach you all the basics. Outbound rules are in the advanced module https://www.3cx.com/3cxacademy/
Hi atlantisegidek,
Make sure that your SIP Trunk settings are set correctly. I have had similar problem with outbound calls not working because Outbound Proxy was not set correctly. Ask your SIP trunk provider to give you correct information.
Hope this helps.
In the company everyone call. I just can't call. I think the problem is with my user. But I couldn't find the problem.
Can you call other extensions though? Can you call *777 to hear echo?
could you give us a screen copy of your outbound rule(s), hide sensitive info
what is your extension number?
I could call before. I did not touch outbound rules. I think there is another problem.
I am sending a photo.
In the 4th photo, I tried to choose the other option. But again I got an error.
Sorry for spelling mistakes.
@atlantisegidek
Did you try reprovisioning/reinstalling the softphone? I have had similar issues and sometimes that solved the problem.
3K8iMGWviZ
