I deleted a user and need to reuse their email address
Build
SMB User
When I try to add the new user, it tells me that email address is already in use. I can't find the user because I already deleted them, how do I fix this? Can I bring back the old user? Can I complete the deletion of the old user?
You may try the "+1" trick, ie if original was aaa[at]bbb.com, now try aaa+1[at]bbb.com
under your portal, how many installations do you see under the 3cx.cloud domain, and if more than 1, are they on the same host? (4 digit number)
I have 2 installs (not sure why) and they're both under 1590. When I click to manage both of them, they both go to the same management console and the users in question are not present.
If anyone could help, that would be great.
LeeonLau
